My 1800A gas tractor has a one wire alternator that shows 14.25 volts at the alternator terminal and 14.12 volts at the battery terminal which indicates to me that it is working normal and charging the battery. The problem is the red light never goes out. From what I read in the owners manual, this light only is suppose to come on when there is no charge. What could cause this to stay on all the time?
The one thing I noticed on this Oliver vs others, is that to start it you turn the ke on and then push a button that is next to the key. On others of this vintage like 1850, 0r 1650, 0r 1600 that I have started, the starter switch is incorporated in the key.
