Ok here is where i have done to date.
Removed the power beyond plug and ran a line to the in port of a charlynn motor
Removed the plug by the filter and ran a hose from the leaving side of the charlynn to the hydraulic reservoir
Started tractor and have 1150 psi of pressure on the outlets when the level is moved
After running the tractor for awhile the charlynn motor gets warm but I do not have any power steering.
I do not know the history of the motor,,,
Do I need to pipe in some type of priority valve or do you think I have a bad charlynn motor.
Thoughys?
Thoughys?
