1850 Perkins valve adjustment
NYOlivers
Does anyone know the order in which to adjust the valves on a 354 Perkins in a 1850? I found the spec for the valve lash just not which valves to adjust in what order. Thanks in advance
start with # 1 cyl. on compression at TDC the adjust those 2 valves. follow the firing order 153624 so you adjust cyl. 5 next at tdc on compression. watch the running mates valves for each cyl. you will be adjusting. when those valves rock you know the cyl your adjusting is on compression. 153
624 here is the running mates. cyl. 1's running mate is cyl. 6
