Oliver mfwd axle applications
mkuhns
At one time I thought I read that the mfwd clark axle such as in the 1655 through 2255's was used in other applications. If so does anyone know what other machines may have had the same axle housing in? I thought it was in a Clark payloader. If so does anyone know the model of it. I need some parts for a 2150 axle and a bare housing. Agco dealers want an arm and a leg, and maybe a kidney for these parts. I was checking for some other possible alternatives. Thanks for you help!
I want to say the Michigan/Clark 35 loader used the same axle, but give these guys a call to match it up exactly:
http://www.steeringclutch.com/transmissiondiscsCLARK.htm
Scroll down to the bottom and you'll see the different axles they carry. Much less money than the dealer.
I've also wondered if there is a good vendor to buy the Clark/Spicer parts from (besides Agco). I looked into it a bit and came up empty handed. I was told that the front axle is an 8000 lb steerable drive axle. I'd also be interested to know if anybody has a parts source for these.
(quoted from post at 17:27:13 12/15/15) I have a complete axle from a 1950 FWA that I would sell parts from. What parts are you needing?
Has been awhile since seeing this ad. if it is still going what do you have fror the axle assembly yet
