Trying to remember how it works in there. Not that it matters, it's been a couple years since I had one off, so I was just trying to refresh my memory. This is what I'm thinking is the way it works, correct me if I'm wrong: the front transmission input shaft bearing is lubed by the transmission splash/channels whether equipped with a belt pulley or not. The oil you add to the belt pulley top plug pretty much all stays up top to lube the bearings and gears of the pulley cross shafts. Or am I all wrong there, and once you fill the belt pulley housing to the proper level it supplies the lube to the front bearing and is retained within the belt pulley housing and the front bearing housing? My mind sometimes won't let itself rest until it knows a definitive answer to something that crossed my mind and wondered about. Thanks guys
Ross
Ross
