Oliver 1355 4x4 purchase and repair
thoner7
I'm considering this tractor for my property, but I know nothing about Oliver's. It appears parts can be had on this website so that in encouraging....
https://rochester.craigslist.org/grd/d/oliver-1355-tractor/6825516701.html
The current owner says there are issues with the trans and 4x4....claims he Bought the tractor with 3rd + 4th gears gone and 4X4 missing shaft in differential. Hydraulics and engine are strong. Says he just always used it as it is.
I would want to get these repaired. Definitely the tranny but the 4x4 just because it's broken. How crazy of a repair is this? I assume split the tractor open but, is it all open and a similar repair to say a Ford of that era?
Also how does that price look to y'all?
Much as I like those Fiat built 4X4 tractors, the unknowns about the tranny and 4WD problems would make me want to get it for $2k max.
Like TF says,parts for that front end could be a problem. That,and I'm always leery of anything with transmission problems. I've got a 1365 FWA. I haven't had any trouble getting parts for the front planetaries on that one through AGCO,but they used a different front end.
CL Ad
First rule of Oliver Fiats, parts aren't cheap. Second rule of Oliver Fiats, parts are expensive if you can find them. Since you want to fix it, $3k is way too high. To me, $3k is a figure someone throws out who's content running a jerry-rigged tractor without all its gears, and is looking for like-minded buyer. Out here, that would be a sub $1k tractor at auction, if the problems were disclosed. Heck, a pretty straight, running, problems unknown 2wd 1465 with ~3k hours sold at auction for $1100 this weekend.
As a lot of our older tractors are out here, that tractor was going to Mexico, regardless of price. I could've bid them up, but I was going to lose.
Sure they can, but not necessarily. I've been to a lot of auctions these past 2-3 years, and it's all relative. The tractor in question here, the 1355, is without question a $3k turnkey project of burning money, especially for someone who's not an emotionally invested Oliver lover/collector.
For a $3k FWA tractor with issues, I'd find a Kubota with issues.
Darn, I figured parts might be trouble. The 4*4 I could live without, I was shopping for a 2 wheel drive anyways. But the front end looked quite stout.
Would transmission parts be easier to fond!? I found gears etc right on this site
Did you get a serial number? I can remember getting some service bulletins on those transmissions because of machining problems on some of the gears.
(quoted from post at 11:41:21 02/26/19) If you keep an eye out you can probably find a parts tractor to get the 4WD parts you need.
How do you guys keep an eye our for tractors nation wide? Craigslist is really only local
Go to Google.com. Pull down the Settings menu. Click on Advanced Search. Put Oliver 1355 in the first line. Put Craigslist.org in the line that says site or domain. Then press the blue Advanced Search button.
That will search all Craigslist ads with Oliver 1355 in all cities that Craigslist covers.
