cracked cylinder head super 88
WORNOUT
have the head removed from my super 88 diesel engine upon inspection found a surface crack on number two cylinder the crack goes from the inlet valve port out to wards the injector side, crack is about 1.5inches long. The compression is good and no signs of coolant leaking into combustion chamber note the crack goes across combustion face and not into recess for valve. Is this something to be concerned about or is it like the gas cylinder heads that have many but operate fine ?? Thanks
