Hi all, I am sure this question has been asked numerous times, but I thought I would try a new thread.
I have a 770 that had the power steering pump mounted to the end of the generator. I would like to convert this tractor to an alternator for a couple of reasons the
primary ones are the generator is shot and I have had trouble finding a replacement voltage regulator that would last. The other reason is also most everything we have
around here is negative ground so I like to be somewhat consistent.
Does anyone make an alternator that the pump would mount on?
Can I use the existing hydraulic system? If so what ports do I need to tap into and do I need some type of flow regulator?
Can or could someone post how and where the lines would go.
