Oliver Tractor Identify
blink4593
New User
Looking for some info on this Oliver Tractor
Tag shows serial number 122138-699
Specification number 36-0158
Any help would be great.
[/img]
I was going to say, that looks like someone crossed an old Oliver and a Lull. I don’t know that I would consider it a “tractor”.
-Scott
Thanks,,, do any of those numbers identify the base model of the tractor? I will need brakes this summer, just trying to get all the right info on this model. I have looked for that specific serial number with no avail, and of course I'm a newb when it comes to older tractors.
Have any pictures of the engine in it?
That would help identify the size of
tractor, and a picture of the brake
housings would tell us whether they are
disc or band brakes. After that, it
should be pretty easy to get the stuff
you need.
I can see a lot of light between the dash and engine area in the one picture, indicating it probably has a 4 cylinder, which, if it does, would make it a 66, Super 66 or 660. Super 66 and 660 have disc brakes as well as late 66's. Earlier 66's had band brakes. All of which are easy to get parts for.
I will get better pics of engine have crappy ones from the barn I found it in. But I do have a pic with brakes, or at least one side.
Yep, those are disc brakes. Unless they
are upsized to maybe 770 brakes since
it's an industrial type tractor, they are
most likely just regular 660 disc brake
parts. Take The cover off, measure the
diameter of the discs under there and
call Korves Oliver. They should be able
to get what you need.
