OLIVER HAY RAKE
I have an Oliver 105 hay rake that the lift screw mechanism has stripped out.
Does anyone have or know where to look for a replacement>
Or even a good way to fix it?
Thanks
Matt
I got a 107 hay rake ,which got stripped the bolt part or the nut part, take it in to a good machine shop they should be able to cut you some threads, on either half, Take the old parts with you so they can measure things. I still need rake teeth for mine, the New Holland is the closet i can find, but there about a 1//2 inch to long!
