Having issues with carb frosting up, usually I run tractor for a few minutes, carb frosts up, I shut it off, wait till it defrosts, start up and is good. had happen yesterday morning, frosted up, leave sit for a few minutes, then was good, I have snow bucket mounted on tractor, I pushed snow for about half hour, no issues. last night went to move more snow, we got 18 inches yesterday, same issues of carb frosting up. went through 3 cycles of starting, thawing, and back to starting. After tractor sits a few minutes, go to start it up, runs smooth till carb frosts up. Then spits and sputters, occasional backfire. In the past I have added a bottle of isopropyl alcohol to gas tank and gets rid of moisture, I also removed drain plug at bottom of the zenith carb to drain any possible water out. Not having any luck getting it straightened out, looking for more options... Thanks
