Hello. I have been working on restoring a Diesel Super 55 and ran into a problem getting ANY output from the generator (Delco) with what seems to be a Vickers power steering pump mounted on the back. The power steering was working, okay, though not great --- that's next -- but the generator really needed a total rebuild. However, the gen had a splined shaft protruding from the end opposite the pulley end and none of the rebuilders had any idea what to do about that (especially since the spline seemed to be somewhat damaged on the one I removed. I found a shop that not only DID fix and totally rebuild the generator but offered to help on the power steering pump, too (it seems that these units are very similar to those used on mid-50's corvettes and they even had spare shafts ON HAND) to rebuild, as necessary. The generator works GREAT, now, and I am starting work on the power steering pump. myself, so far.
Here is contact information for the outfit that I used should you need such services:
Ole's Carbyretir & Electric Inc.
120 El Camino Real
San Bruno, Ca. 94066
Phone (650) 589-3934
They are REALLY nice people.
For seals for the pump, check with:
O'Brien County Implement
111 Country Club Road
P.O. Box 156
Sheldon, Ia 51201
Phone (800) 320 320-6224
ALL of these people understand the difficulty of trying to maintain and fix the older equipment.
I hope that this might help others trying to repair their old equipment.
Gil
120 El Camino Real
P.O. Box 156
Sheldon, Ia 51201
Gil
