Cockshutt 415 pitman arm trouble
arondegier
New User
Does anyone know the part number or dimensions of the pitman arm for the Cockshutt 415 sickle mower? Seeing a lot of different ones but don't know which one to get!
We don't have a manual and not finding one by searching online.
Does anyone also know how to align the pitman arm with the mowing arm so that we don't break another pitman arm?
Hi Phil.
thank you for helping us out with the dimensions.
do you know the name of the part that's between the pitman arm strapping closed to the knives.and possible the part number?
i know i ask a lot thanks for helping us .
Aron
Could you just share the pitman arm part number as well as the link on/between the strapping? That's all we need to know.
Aron,
At the sickle bar end of the pitman on a COCKSHUTT BUILT #315, (should be the same as the #415) The Latch assy. is GY-2906. The pitman assy. complete is GY-2968. After Oliver took over Cockshutt Farm Equipment in 1962, Oliver changed the mower model number from #315 to #415. The #415 was offered in OLIVER name and green & white paint in the USA and COCKSHUTT name and red & white paint in Canada. Oliver re-assigned new part numbers on all the parts. AGCO should be able to cross over the COCKSHUTT numbers that I listed above.I have not yet gone out to get the stick dimensions. Hope to get it done today................Phil 215-256-8651.
here is a copy of the page from 415 parts book. on bottom I added the measurement's for the pitman arm. if you cant see it email me and I will send it to you. Irv
Hope full Phil will be able to verify my measurements. [email protected]
