1365 bellhousing
krustyman
New User
Gang,
Does anyone know if the 1365 has an SAE style bellhousing? I found one for a deal with a blown engine and was pondering if I could swap in something else like a 3-53 if it would support a SAE housing.
Krusty,
Found some posts from Mitch Poindexter showing his restoration and it seems like the motor is integral to the tractor and a swap would not be possible as
their is no frame. The front axle, rad, etc are connected to the front of the motor from pics I have seen.
I got to thinking about that yesterday after I told you to post down here. That block is pretty thick and reinforced. There are several other brands of tractor that were basically the same thing. You might be able to just by a running off brand of tractor and swap the engine.
