Oliver 550 transmission
I have an Oliver 550 with a potential bearing bad in high gear.
Is there any easy access to inspect this? Without splitting tractor?
If it does need a bearing replaced for high gear, is there access without splitting tractor?
Your experience and suggestions must appreciated.
Pics?
Thanks
Ty
You can see more by removing the hydraulic unit. Also fifth and sixth gear are the same gear. Do you have a shop manual?
OK thanks ...
Just trying to investigate it a bit, before I decide on what to do.
It has a loader and a hoe on the back. So, not easy to split.
The gears are under the hydraulic unit IF it has a factory hydraulic unit. If it has just a cover remove it. There are no transmission gears under the center section.
(quoted from post at 21:18:51 01/26/19) The gears are under the hydraulic unit IF it has a factory hydraulic unit. If it has just a cover remove it. There are no transmission gears under the center section.
Ihave a550 that keeps popping out of first and third gear. I have read where these tractors have had shifting fork problems any help would be appreciated
