PtownBubba
I did a search here, and there were some chats about 770 oil. It seems some guys guys say to use either 10w30 motor oil, as it helps out the Power Boost,,, or 80-90, with or without a PB, it makes for quieter transmission noise. The book says to use 19 qts. of either 5w-20 or 10w-30,motor oil,, with the 102 082A additive, [which is obsolete].
So, in cold Northern Illinois, with a 1960 770 with a working Power Booster,,,what is the definite answer to this oil question: 10w 30 motor oil, 80-90 gear lube or some even say Hy-Tran ,,,,,,,,,,,,,???
[/url]
[/url]
