Company Logo Shop Now
TractorLinks.com
Oliver oc 3 questions
mikewood869
01-10-2019 10:29:26
Just wondering about an Oliver oc 3 crawler tractor with dozer blade and pto. The crawler has a mag. Supposedly the last time it ran was in September on starting fluid and before that was god knows when. At the moment the starter is of the tractor. The wiring is junk and the belt pulley is gone. How hard would it be to pull start the tractor and run it for a minute (probably should just stick a bar into the flywheel and turn it over by hand first?)? Have no clue about a wiring diagram. If the starter was to come back, would the tractor run on 12 volts? For fuel tank, I have a one gallon snowblower tank.
dblair
01-11-2019 14:49:16
 Re: Oliver oc 3 questions in reply to mikewood869, 01-10-2019 10:29:26
put it in 3rd gear and give it a yank . done it many a time .
rrlund
01-10-2019 12:16:38
With a mag,you don't need a battery to start it. A mag makes it's own electricity. A 12 volt to turn the starter won't hurt a thing. I'd unhook the wires to the generator and regulator before I tried it is all.
mikewood869
01-10-2019 10:31:26
Sorry I meant the pulley on the motor was taken off, not the belt pulley.
RBoots
01-10-2019 19:13:35
 Re: Oliver oc 3 questions in reply to mikewood869, 01-10-2019 10:31:26
Some had a water pump, some were thermo-
siphon cooling. Probably not the best to run either for too long without the fan or water pump turning.
Ross
