Company Logo Shop Now
TractorLinks.com
1964 Oliver 550
jpert
01-09-2019 10:46:39
I recently purchased a 550 Oliver I have been checking fluid levels and found no oil showing on the hydraulic Dipstick. I have not received the books I ordered so can someone tell the capacity?
SW3
01-09-2019 20:32:55
 Re: 1964 Oliver 550 in reply to jpert, 01-09-2019 10:46:39
Also, the hydraulic oil is held above the rear end gear oil. There is a steel pan below the hyd oil that sometimes develops rust holes and then the hyd oil will leak down into the rear end gear oil. So just keep an eye on the hyd oil level. To check the rear end gear oil there is a square pipe plug just above and to the right of the pto shaft. The gear oil should be level with the bottom of the hole. Capacity is 5 gallons. I use 80W-90 gear oil. Good luck!
SW3
01-09-2019 20:27:18
Welcome! You will love your new 550! Here is a link to an article that can be found on the left side of this site under, Research and Info, Articles, Maintenance.
chucksoliver77
01-09-2019 11:07:19
9 quarts
coshoo
01-09-2019 18:30:30
 Re: 1964 Oliver 550 in reply to chucksoliver77, 01-09-2019 11:07:19
But don't just pour in 9 quarts- add a quart, check the dipstick. Repeat. It could be just below the stick.
jpert
01-10-2019 15:34:46
 Re: 1964 Oliver 550 in reply to coshoo, 01-09-2019 18:30:30
Thank you all for the help and information. Today I spent the day at the farm store getting bushings and pins to tighten up the seat. It was so worn the gear shift knob was hard to maneuver around the seat. I am a 30 year retired Caterpillar mechanic. The fun is just beginning.
