young tractor
Hi guys. I?m pretty deep into an 1850 with a Perkins fix up and
paint project. I have an injector line that is leaking at the
threaded fitting that is attached to the injection pump. What do
you recommend to replace this line. Can I use either copper or
steel brake line to replace and re-flair each end? Or how
would you fix it? Is it a double or single flair? I assume the
flair is bad on the line. Thanks for your advice.
