Oliver 60 Row crop dimensions
amtrac
Can anyone with a 60 row crop Oliver give me the heights at the hood and at the top of the stack? Also, what's the total width at the rear with normal 9-32 tires? I want to transport a tractor in an enclosed trailer and don't want to show up with one that is too small. Should the un-ballasted weight be around 2500 to 3000 pounds?
(quoted from post at 18:49:06 01/03/19) Can anyone with a 60 row crop Oliver give me the heights at the hood and at the top of the stack? Also, what's the total width at the rear with normal 9-32 tires? I want to transport a tractor in an enclosed trailer and don't want to show up with one that is too small. Should the un-ballasted weight be around 2500 to 3000 pounds?
Tractor data has some dimensions. Would be best to have the one you're hauling measured. Exhaust is probably not original height. Tires may not be original. Came with 28 or 32. Rowcrop width can very and chances are hubs wont move easy.
amtrac, I just went out and measured my Grandson's tractor. The hood is off, but the steering wheel is higher then the hood.
top of exhaust, 82 inches
top of steering wheel 6 foot
Front of front tire to tip of draw bar, 129 inches
End of rear axle to axle, 80 inches
this is on 32 inch rear rubber.
I hope this helps you out.
