Oliver 500 Wa
Tacked together in the flat. After welding, I'll form the curve. Still have to machine the mounting stud and lower pins.
Also have to figure out the screen. I have found there were two different screen types used. It seems that early tractors had a finer mesh screen with finer wire than the screens on later tractors which was quite a bit more coarse with heavier wire too. The sample grille has the fine screen. I'm thinking the coarse screen would allow better airflow.
