Oliver 1265 starting aid
hs528
New User
Hello,
I have a 1265 Oliver that I am trying to find a new Intake heater for. I have found one for a 1365 but not listed for a 1265. Not sure if there would be a difference between intake heaters for these two models. Does anyone have any insite on the correct intake heater for this model? I also have a part number off the side of my old intake heater but does not seem to be helpful when searching for a new one.
Thanks,
Levi
I'm pretty sure the heater for the 1365 and the 1265 would be the same.I'll check today to see if the heater on the 1365 and the AC 5040 are the same if so then the 1265 would be the same.I looked up pictures of the heaters and the one for the 1365 looks like the one I just got for the Perkins 354 in my Long/Landini,turns out it didn't need a new heater it was wired
up wrong.
Appears to me the 5040 and the 1365 have the same heater in the intake.Also have you tried hooking up the heater plug with a jumper wire? Most of the time its a wiring problems in the switch on the dash that quits working like it should.
Thanks the information, I got a intake heater ordered for my tractor on Friday. Looks the same from the pictures I saw. The intake heater I have is failed, the coil is open. The wiring and switch are fine. Thanks for your help.
