Starting super 55
I used Diesel Tech's advice on starting super 55 diesel yesterday.
with out a doubt tractor started easiest that it ever has started in cold weather. Thanks for the advice Diesel Tech. you can always learn something on this forum.
If you take the head off, make sure you install valve seats and set the valve recession. If you are going to put a set of sleeves & piston in it, install a set of 3-5/8 sleeves & pistons in that will all help!
