PtownBubba
Does anyone have a map of the hydraulic connections on a 770. It has an add on 2 lever loader valve, and normal stock hydraulics. There area a couple unused ports, what is their function. The return hose for the loader valve is tucked up in between the hydra. unit and firewall,,,, impossible to change that hose, without removing hydra. unit cover,,, can that return go anywhere else ?
