Yep, been there, done that, got the t shirt. The seal between the drop box and the transmission is leaking. You will have to pull the motor and hydra power and split the frame in order to change the seal. OR, get a long hose that fits the fill tube on the drop box and run it back to the PTO housing , take out one of the plugs and put a pipe nipple in and hook the hose up to it and let the oil recirculate back to the rear end. Chris
