1855 clutch disc.
bison
Would anyone here know what the original thickness of a 6 button clutch disc is supposed to be.?
Thanks
(quoted from post at 15:14:27 12/22/18) Would anyone here know what the original thickness of a 6 button clutch disc is supposed to be.?
Thanks
0.402-0.394, 6 button, 12 spring "Pink". I am new to this, so I didn't exactly reply to your post correctly the first go around.
(quoted from post at 15:44:16 12/22/18)
Thanks
Did you need the pressure plate to flywheel specs/finger adjustment as well?
I have them if you do need them.
(quoted from post at 20:32:40 12/22/18)
Thanks
Thanks,..
No, I have these finger adjustment specs.My manual did not mention the disc thickness,..that's why I asked.
The Clutch was working fine but I am rebuilding this tractor front to back top to bottom and I am looking at every part.
Looks like my clutch disc is still within specs after 46 years and 7000 hrs.
