White 1730 QA loader mounting
Kegejd4440
New User
I'm thinking about purchasing a white 2-105 for a loader tractor sense I came across one cheap. Well today I came across a white 1730 QA loader but it's mounted to a oliver 1755. My question is would the mounts line up on the white 2-105 or am I gonna need different mounts
Depends on whether it bolts entirely to the sides of the frame or if there's a mount on the front. The side pads should be the same,but the front of the frame is rounded on the 2-105 and doesn't have any bolt holes like the 1755 does.
Rounded like the weight bracket rounded?
Yes. If that was unbolted and off there,the tub would be pretty much the same as an 1850,but they needed that extra length for everything they put ahead of the radiator.
so basically if I just unbolted that weight bracket off the white 2-105 it will fit? If I'm understanding correctly
No,you can't really take that off,the grill is bolted to it. You'll need loader brackets that bolt entirely to the side of the frame and not to the front.
I believe I have that loader on my 2-88. The mount wraps around and on top of the weight bracket. You can't put weights on it with the bracket on. It
sticks out just a little in front of weight bracket.
