PtownBubba
It looks like the right lift cylinder is oozing oil out the top ,,,, I saw a video on how to change the seals,,, not a bad job,, does the loader have a 2 1/4 bore [piston] or 2 3/4,,, the outside diameter of cylinder is about 3 inches,,,, ??? I am guessing the 2 1/4 seals are for bucket cylinders,,, and the 2 3/4 seals are for the lift cylinders. I would like to have the seals when I take it apart,, so it can go right back together, shorten down time,, I found a place in Ohio, where the guy said he should have the seal,,,, or seal kit,,,, ?
