I found a 1966 1850 that has been sitting without starting for 2 years. It started fine and runs good and everything works goods and it has no hydra power which I like. The one problem it has is it that it is leaking fuel from a little hole in the injection pump. The guy says that there is a diaphram that is bad internal inside the pump which would costs about $600 if wanted to fix it. He also said that the leaking diaphram really dosen't affect the performance of the engine and you can just plug that hole to stop the leak without any side effects. He said that he has done it on his Massey with a perkins engine and had no problems.
Tell me what you think?
Also the tractor has 16.9x38's on the rear. was this an option for this tractor? All i have seen had 18.4x34
