young tractor
Hi guys I?m starting to dig into my 1850 diesel now that it?s winter. I took the left wheel off to replace the axle seal. I found steel shavings on the seal and axle. I can see one roller on the bearing that looks bad and the bearing seems rough when spinning the axle slowly. I have a book on the tractor. If I understand this right. I take the snap ring off the bull gear , then unbolt the housing and slide the whole axle and housing out of the tractor. How hard do the bearings come off the shaft. I appreciate any do?s and don?t?s of doing this. I probably should check the right side too. Thanks in advance for your advice.
