Super 55 clutch shaft
super 55
Location
Whonnock BC
I have my Super 55 split for a PTO rebuild. With the tractor split there is access to the clutch shaft where is goes through the PTO drive pinion. The clutch shaft has play in it, up and down and side to side. Is that because it isn't supported by the clutch drive hub on the other front end? Don't want
to have to take the transmission cover off if it's unnecessary.
