Oliver 88 engine parts into a 77
ColeHans
I have a lot of parts off a 88 and recently got a 77 that I want to build into a puller, I’m wondering if a 3 3/4 bore kit from an 88 would go into a 77 block, I have the sleeves pistons and rods and also would the 88 intake set up work on the 77?
None of the rotating assembly is interchangeable between the 77 and the 88, if you want a 3-3/4 bore buy the kit for the 77 from
Korves.
Rich
what about the intake and exhaust manifolds, are those a direct bolt on, or is the 1550 or 1650 head a direct bolt on? I have a 1650 head on my 88 but I can’t remeber if it will bolt. Right onto a 77
