oliver90owner
- Location
- UK
I am currently unable to do much, not even removing wheel fixings.
Please can someone enlighten me as to whether the rear axle splines for the Industrial are the same as, or different to, the Standard? The
Industrial has a very large nut retaining the wheel, while the Standard uses a stud.
I suspect they are, so will eventually need to remove the Industrial wheels and replace the tyres. The tyre size is currently 24 x 18 (but will
need to be 16.9s maximum, to avoid just touching the belt pulley).
RAB
RAB
