White 2-75 4x4
RCP
Location
Grove City Pa
I am interested in a White 2-75 4x4 with a loader, it is an estate situation and the tractor has not been run in 5 years or
more. It has been left outside with the exhaust covered, but not sure it has been covered the entire time. Current owner has not
tried to start the tractor. Tires are worn but seem to hold some air pressure. Metal work is all there.
Is this a desirable tractor?
How difficult or expensive are parts?
Where to get parts?
Is it worth bringing back?
Thanks
Rich
Parts list shows engine has an inline injection pump. I'd remove the front rack cap if possible and see if it moves freely in-out. Setting that long it MAY have one or more plungers stuck which will show up by no rack movement. DON'T attempt starting it without knowing rack is free. If it's stuck outward with just one plunger, engine COULD overspeed and cough a rod through the block. If rack is stuck inward, engine won't start at all.
That is a Iseki built tractor. Some parts are getting pretty hard to get. AGCOs support is spotty on them too. With it not running it I would not give much for it. You may just be buying a salvage tractor. Any idea why it was not run in the last 5 years??? It very well could have had troubles when it was parked.
JD Seller
I agree, I do not expect to get a good answer on why it was parked. The previous owner passed away and the tractor sat until the heirs decide to clean up the farm.
Thanks
Rich
Ihad 2-65 awd with loader it is Izick japan tractor same tractor as 2-75 . got rid of cant get parts for them
broke front axel one dealer wanted 3500.00 one.
I'd be interested in that 275 if you don't buy it. I could use it for parts. If you don't buy it, would you share the contact info?
