Oliver 1750
Logan_0317
New User
I have an oliver 1750 gas with the 283 waukesha in it. I am looking for a factory fuel lift pump that is mounted on the side of the motor and ran off of the cam. Having trouble finding one. Could probably get by with just a rebuild kit. Any help or information leading me to one is greatly appreciated
Later tractors did away with the mechanical pump and used an electric fuel pump. You have a snail mail address because I can send you some information. J.
I have tried multiple electric pumps and had the problem of either too much pressure or not enough. Also tried putting a regulator on along with a pump and still not fixing the problem. Wanting to try getting an original pump on it and see what happens
Like Princeton Bill said,try Korves Oliver,or try Agpartsfirst dot com. One or the other has them listed. I just saw the ad the other day. I just don't remember which place it was right off hand.
Ag Parts First. 1-866-264-9720. There is no reason you should not be able to find a pump for that engine, I would think.
