I have an 1800 that I was going to use to blow snow today. It started right up, but when I pushed in the clutch, it would not disengage. I have the pedal adjustment all the way in and still no disengagement
This summer I had the same problem a few times , but starting and playing with the clutch pedal, finally it would work and work fine for the rest of the day. I don't use or start this tractor no more then once every few months. Also, it does not have hydra-power. What could be the problem and is there a easy fix?
