Tractorcedric
- Location
- Garland. Utah
So I have an A model 1600 with an Oliver loader on it. Sometimes I mount a hydraulic post hole auger to the loader bucket. I have a coil operated valve that can run two circuits. I don't use the hydroelectric so I plan to use that switch to operate the valve. The valve has seven ports, one for pressure, one for return, four for the two circuits and then a small one that I think is to relieve pressure so that it can shift. The pressure and return will come from the bucket section. My question is, were should I plumb the small line to return to reservoir? One circuit will run the bucket and the other will run the auger. I will just hold the button down to run the auger. Hoping that operating the coil will relieve pressure on hoses so that it will be easier to quick connect the couplers! Clear as mud? Thanks
