1755 has had lagey/darty steering since I bought it 2 years ago, I thought the system had air in it from some leaking lines. I finally replaced all the line and after filling up the system and doing figure 8's for awhile the issue remains. 6th over is the worst, down the road the tractor will drift and when I correct with the steering wheel it takes a few seconds for the tractor to respond. Also in 1 under I can see the tie rod linkage move if I run over rough ground but no feedback in the steering wheel. It appears the steering was upgraded to a Char-Lynn at one point. So my question now is it the orbital steering motor or the steering box? How would I determine which is acting up?
Jason
Jason
