283 waukesha injectors
bison
Does anyone know make and # of these. crossfire injectors.
no OEM # please.
I need the cap nut copper sealing washers,..Anyone knows the size?
AGCO wants $ 30 a piece :shock:
Thanks.
Which injector brand, American Bosch or CAV? If I recall CAV use NW 60. I may have some, but not sure. If they are not beat up bad they can be used again, return side has no pressure on it..
Bison: Late ones were Robert Bosch They can be identified by the hex being smaller than other cross fire injectors. The same gasket will work on any of the three.
Thanks guys.
A couple years ago I reset the pop pressure on these injectors but the injectors keep on sweating on these washers. At that time I heated these washers up to try restore them but it did not work I guess.
Time for new ones I guess....but not from Mafia AGCO.
(quoted from post at 11:31:05 11/02/18) I do have some NW 60 washers. Any copper gasket is priced like gold anymore..
need 6...how much?
I'm in Northern Alberta.
