Oliver 2655 need help with parts
TangleFoot
New User
I have, and farm with an Oliver 2655(MMA4T1600)
It has a HD800.
Looking for good places to get engine rebuild parts.
Also looking for complete decal set
any help is much appreciated,
TangleFoot
Forgot...also looking for a set of rear fenders
for decals call dumont musuem in sigrouney iowa. they make decals for anything that has the name oliver on it. you may want to go to the minniapolis moline forum for engine part advice. those fenders are going to be hard to find.
Back in a former lifetime so to speak when I traveled for Perfect Circle machine shops they had engine parts to rebuild those engines. Perfect Circle Parts are now Clevite parts and no NAPA does not handle Dana engine parts any more.In fact it is not Dana anymore anyway, it is now Mahle. You want part numbers I can get them. Not all 800 engines use the same exhaust valves either, I remember seeing Moline bulletins that explained all that.
OK, Thanks guys.
I will check out the musuem in Iowa for the decals thanks.
I did check with Welters in MO and will probably go there for parts but was checking for other options.
do you remember what the difference in the valves were? ain't got them out yet.
Anyways, thanks for the responses
Later, TangleFoot
