Implement question
I have an Oliver 22A sickle mower and need some parts. I have purchased a model 82 mower, it looks like the bar and pitman will work. What is the difference between the two mowers?
I still need a sickle, are new Oliver sickles available or will another sickle work?
Thanks
John Schoenauer
The pitman and bearing are different. 22A had a needle bearing and the 82 a sealed ball bearing.
Also the pto shaft will differ but still interchange. The 82 would have the more modern rolling shield. Also the later 82 had a heavier pto than the early version to handle the extra load of a trailing crimper.
