LaVern Skarzenski
Hello All,
The other day I posted several questions concerning a narrow front end 70 we used to have on our dairy farm back in the late 50s, early 60s. Perhaps I should have done what I am doing now and start a new topic. I posted it in the topic of "Oliver Firsts". I have copied it to here.
[color=green:01cdab171d]Hello All,
Several people here in this (Oliver firsts) post have mentioned "front wheel assist". Is this a front wheel drive assist or a steering assist? I ask this because back in the late '50s and early'60s on our dairy farm, we had an Oliver 70 with a narrow front end. My younger brother accidently drove the tractor over an embankment and the front wheels ended up snapping off in a cement culvert. While in the process of replacing the casting that supported the front wheels (I can't think of the proper name for this casting right now), I noticed two arms that were attached to the steering gear (another improper term) if I remember correctly. What I seem to remember was that these were an option that allowed the individual brakes to be applied, depending on which way the wheel was turned. Is my memory somewhat correct on this or is this just something that I, as a 14 yr. old mis-interpretted? I think the manual showed cables running back to the brakes and somehow turning the wheel in either direction all the way activated corresponding brakes. Our 70 did not have this though.
Also did the 70s have 6 forward and 1 reverse or 6 forward and 2 reverse gears? I remember only one reverse. My brother remembers 2. My recollection is reverse was in the "lower" neutral along with 2nd, 4th and 6th. I know this is Off Topic but I've been meaning to ask this for quite some time and the above postings got me to ask now. Thanks. [/color:01cdab171d]
Thanks for any information you may have.
LaVern Skarzenski
LaVern Skarzenski
