Hi guys,
Any ideas on what to do with a cracked manifold on the top of the hydro pump?
Could this be repaired, or am I looking at getting a replacement?
There's a crack right through casting at the outer edge of the outlet port, between the threads for the hose fitting and the outside. I got a new outlet to valve hose installed thinking the old one was leaking, and took it apart when the new one leaked as well, and found the crack.
Anyone know if there were other tractors using the same style pump and inlet/outlet manifold combination?
Thanks,
Eric
Thanks,
Eric
