Shawn MacAnanny
This is on an Oliver or White industrial 550 backhoe. The engine mysteriously siezed up after its first start up and just as mysteriously unseized when i had it apart. Anyway i dissasembled and clean the head and valves while i had it apart. i pressure washed the head and cleaned valves and seats with laquer thinner.
The pictures are in order starting with the cylinder closest to the transmission and moving forward. The intake valve seats all looked fine to me but the exhaust valves all looked pretty rough. I dont have a whole lot of experience which valve jobs, i just take it to my machine shop so i dont know what good is exactly. It's probably fine although i think the burning on the 1st cylinder is a little strange. I included a picture of the injector for that cylinder since it looked like it was possibly leaking. The rest of the injectors didnt have the large holes this one does. The pistons and cylinders walls look perfect in all cylinders. I also forgot to get a pic of the one valve after i cleaned it.
Burning of cylinder 1
Exhaust seat cylinder 1 (rear of engine against transmission)
Exhaust valve cylinder 1
Intake seat cylinder 1
Intake valve cylinder 1
Exhaust seat cylinder 2
Exhaust valve cylidner 2
intake seat cylinder 2
intake valve cylinder 2
Exhaust seat cylinder 3
Exhaust valve cylinder 3
Intake seat cylinder 3
intake valve cylinder 3
exhaust seat cylinder 4 (front of engine)
exhaust valve cylinder 4
intake seat cylinder 4
intake valve cylinder 4
cylinder head side
cylinder head bottom
Possible leaky injector (injector on burned cylinder)
cylinder head side
