310 oil leaks
Anonymous-0
I have a 310 motor out of an 1855 that is leaking out of the govenor seal and also the front seal. It looks like I will need the govenor seal and mounting gasket, timing cover gasket, front seal, and oil pan gasket. Are there any other gaskets or seals that I may need and is there a gasket set that I can order that would include all these seals and gaskets at a cheaper rate than buying the gaskets and seals individually? Thanks for your help!
That engine should have a lip seal. You should not need a pan or front cover gasket. You just need the governor gasket. Questions?
