Hi All, I have the 770 in the shop to upgrade a few things, this tractor has Charlyn power steering and as long as I've owned the tractor has leaked at the high pressure hose fitting because when it was installed they didn't use a swivel fitting so corrected that I now have a idea why they did that way, first the oil pressure light switch was in the way, fixed that now I see I can not reconnect the tach cable so my question. Can I remove the 4 screws that hold the drive adapter to the dist, rotate the drive 90 degrees there is enough cable to connect that way.
GB in MN
GB in MN
