Cockshutt 30
1031D
I am looking at a Cockshutt 30. It used to run and work fine, someone tore the engine apart for an overhaul and lost interest and a couple parts. Where is a good place to find bearings, sleeves and pistons, valves, ect? I see www.agkits.com has a couple things. It is a Buda 4B153? gas engine.
I second the vote for Phil. I am pretty sure he can find anything you would possibly need. You can also get the majority of the engine parts including piston sleeve kits from your local Napa store as well.
Well I contacted Phil last night and this morning he shot me a quote to rebuild the engine and replace all the wear parts, not bad either! I Figured a Buda engine would be expensive but I guess not! Now to get it home.
