John Schoenauer
I recently purchased an Oliver plow. The plow is red I haven't taken time to see if there is another color under the red. I thought it might be a Plowmaster but the frame pieces are all straight, not bent from the top frame around to the plow lay. I started looking again and now believe it is a 42_ _ or 43_ _. I have read that the first number being 4 means it is a pull type. Can someone explain what the rest of the numbers mean?
The plow is old enough to still have the rooster comb hub on the landside but the plow has been converted to hydraulic lift. Most of the plow has been painted red except the wheels and the framework for the hydraulic lift which are green. I will try to post some pics when I get time. I found some manuals online for the 4240 and 4340 and can't see much difference.
Another question was the spring loaded hitch an add-on? The manuals show a standard hitch (no safety quick release).
Thanks for your help
John Schoenauer
John Schoenauer
