Cockshutt 540 Weight
Filoche
New User
Hi everyone.
I recently bought a Cockshutt 540 for restoration project. However, we cant find how this tractor weight.
Anyone got that information? Also, if anyone has an official source for this we could use it for the license registration.
With respect,
Phil
(quoted from post at 11:59:31 09/08/10) My 540 has spinout rear rims and the rear tires are loaded and it clocks in at 5070lbs
Hope this helps
Thank you sir for this answer.
Best regards,
Phil
The COCKSHUTT 540 shipping weight with three point and PTO was 4325 pounds. Add 280 pounds for rear wheel weights set. Add 140 pounds for front wheel weights set. Loaded tires would also add lots of extra weight.
Phil Heisey
215-256-8651
FAX 215-256-1203
(quoted from post at 01:29:18 09/10/10) The COCKSHUTT 540 shipping weight with three point and PTO was 4325 pounds. Add 280 pounds for rear wheel weights set. Add 140 pounds for front wheel weights set. Loaded tires would also add lots of extra weight.
Phil Heisey
215-256-8651
FAX 215-256-1203
I'm taking note of this.
Thank you for your help, I appreciate it.
With regards,
Phil
