2-85 and loader
wmthrower
Might have a chance to pick up a 2-85 and a 1730QA loader. Different sellers so loader is not attached. I've only ever seen pics of these loaders plumbed through the remotes. Is there another way to plumb them so that I could use the remotes without taking the loader off? I guess I could just unhook the hoses. That wouldnt' be too difficult.
Yes,you can put power beyond on those with just a couple of fittings. If you buy them,just post and somebody can tell you what you need and how to do it.
Remember the 2-85 is closed center so make sure you have a closed center valve. I would also use a valve that has a float position on one spool. More questions? J.
